Speedometer signal voltages
1998 FORD E-SERIES VAN
53,000 MILES • 7.3L • V8 • 2WD • AUTOMATIC
KEVIN1954
  • 15 POSTS
Speedometer inoperable, good speed sensors and wiring. Wondering what color are the signal wires to the the speedometer head and what the voltage readings should be?
Mar 6, 2018 at 8:29 PM
Good morning.
Do you have a scan tool to monitor the input to the PCM from the sped sensor? you need that to see if it is generating a signal to the PCM. if it does, then it is transferred to the cluster to display a mileage and speed. you cannot see a voltage as it is a pulsed reading that goes to the cluster.
Mar 6, 2018 at 11:16 PM
KEVIN1954
  • 15 POSTS
Thanks Roy.
Mar 7, 2018 at 12:40 AM
You are welcome.
Mar 7, 2018 at 1:15 AM
