Speedo cluster
199,466 MILES • 1.8L • AUTOMATIC
TAULA
Hi I have a 97 Honda odyssey and the speedo cluster is stuffing up. The rev needle doesn't move and stays at 0, the odometer had stopped, the engine light goes on and off sometimes, the D light flicks off and on as well. The odometer and rev needle move after I hit a bump but then stops again. I have replaced the speedo cluster but the problems are still there what do you think it is???
Feb 20, 2016 at 3:03 PM
THIS IS MIKE
  • 686 POSTS
Check the VSS vehicle speed sensor on the transmission for a loose connection.
Feb 24, 2016 at 4:34 AM
