2000 Honda Odyssey speedometer needle
2000 HONDA ODYSSEY
STEVE BOYD
Electrical problem
2000 Honda Odyssey 6 cyl Front Wheel Drive Automatic 184km miles
My speedometer needle is jammed full right but looks like it is still attached. The mileage numbers still work as usual though. Do I need a replacement instrument cluster to fix it? (Likely unrelated, tranny replaced 1 month ago.)
Sep 21, 2009 at 3:29 AM
KHLOW2008
  • 41,814 POSTS
Hi Steve Boyd,
If you had jumped started the vehicle or connected the battery with ignition switch ON, it could cause the needle to overshoot.
Remove the meter cluster and turn the needle back to the zero position and it should be working again.
Oct 8, 2009 at 3:43 AM
