Speed sensor locations
184,648 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TMB795
  • 8 POSTS
while driving the ABS, brake,, check engine light will come on and speedometer will stop working and transmission will not shift right. i have cleaned the front ABS sensors
and it lasted 1 week and then i had same problem.
i am looking for the locations on the engine for the sensors to replace them one is under the air cleaner and the other one i have found yet. could you give a diagram of the sensor locations? thank you
Dec 1, 2019 at 3:26 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Well, having all the malfunction indicator lights on means that all the systems you've mentioned have fault codes stored in you vehicles computer. Here is a tutorial showing what is involved to check vehicle codes.If you don't have access to a code reader/scanner most auto parts stores have a tool loaner and can rent you one, or, some will check for free.
After performing this procedure get back to us with all the code number information including engine,transmission, ABS, etc., and then we can properly diagnose all your vehicles issues. Hope this helps and thanks for using 2CarPros.
Dec 1, 2019 at 4:00 PM
TMB795
  • 8 POSTS
Danny, here is the code: PO500 , Engine is 2.4L , trans auto with OD, ABS.
Dec 1, 2019 at 10:34 PM
DANNY L
  • 5,648 POSTS
Hello again,
I've attached instructions below on how to diagnose the trouble code P0500 for your vehicle. Also attached below is a picture location for your input and output vehicle speed sensors.Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 2, 2019 at 8:30 AM
TMB795
  • 8 POSTS
Danny, thank you so much for your help. it will be a few days and i will let you know what i find.
Dec 2, 2019 at 12:18 PM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, keep me updated.Thanks again for using 2CarPros.
Danny
Dec 2, 2019 at 2:35 PM
