Speed sensor dash light
1993 HONDA
154,000 MILES • 4 CYL • 2WD • AUTOMATIC
VANESSA BAXTER
  • 5 POSTS
Speed sensor dash light is on it does not flash.
Speedometer working and car is shifting.
What could the problem be?
Mar 14, 2017 at 7:30 PM
CARADIODOC
  • 34,414 POSTS
There's no such thing as speed sensor warning light. If you are referring to the red Check Engine light, there are dozens of defects that can be detected. If a defect refers to something that could adversely affect emissions, the Check Engine light will turn on.
The place to start is by having the diagnostic fault codes read and recorded. Normally the people at most auto parts stores will do that for you for free, but they can only read them on '96 and newer cars. You will need to find a mechanic with a scanner that works on a '93 import model.
The fault code will indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. They do not ever say to replace a part or that one is bad. When a part is referenced in a fault code, it is actually the cause of that code about half of the time.
Mar 15, 2017 at 9:48 AM
VANESSA BAXTER
  • 5 POSTS
Not the red battery warning light
It's the green S light under the engine heat gauge
Mar 15, 2017 at 10:12 AM
CARADIODOC
  • 34,414 POSTS
The "Battery" light is different than the red Check Engine light. I'm not familiar with the green light. Any chance you have the owner's manual?
Mar 15, 2017 at 11:18 AM
VANESSA BAXTER
  • 5 POSTS
I do have manual.. On page 20 under dash lights.its called a speed sensor light...says if flashing.then the speed sensor that connects to transmission isn't reading speed correctly.soap says causes poor shifting of gears . Transmission problems, mines stationary no flashing.. Car shifts fine
Its a square GREEN LIGHT WITH A SINGLE LETTER CAPITAL S IN THE SQUARE..smile. on rt, lower side of dash
Under the temp. Gauge...
Mar 15, 2017 at 12:20 PM
VANESSA BAXTER
  • 5 POSTS
Hoping someone who knows older Honda's has ideas on why light may be on.
Mar 15, 2017 at 12:22 PM
CARADIODOC
  • 34,414 POSTS
What model and engine size do you have?
How did you arrive at your user name? Are you a fan of Last Man Standing, like I am?
Mar 15, 2017 at 12:52 PM
VANESSA BAXTER
  • 5 POSTS
It's a 1993 Hinda accord LX 4.0
Automatic.... Yes i like movie Last Man Standing
And that's my name...
Hope someone can tell me about the dash light... Had a guy say could be a simple O2 sensor causing it to be screwy
Think I'll just change the O2 sensor and see what happens... Probably will have to get the dash light turned off...
Mar 15, 2017 at 1:32 PM
CARADIODOC
  • 34,414 POSTS
Oxygen sensor codes are set in the Engine Computer. There are dozens of them and they mean very different and specific things. Don't waste your money on an unneeded oxygen sensor. That will just lead to disappointment when the green light is still on. Check Engine lights are always red or yellow.
Being a green light you're seeing, that implies it is related to something not serious. The only thing I can think of goes back to the late '80s and early '90s when some cars had a "shift" light on the dash. Those were only used with manual transmissions. People thought they would get the best fuel mileage if they up-shifted when the light flashed on. In fact, the light did turn off each time you up-shifted, but that wasn't it's purpose. The actual purpose of those lights was for emissions testing. If you drove the car normally without paying any attention to that light, there could potentially be brief moments when emissions jumped too high. Rather than using common sense, that was enough for the politicians to have a hissy-fit and require pounds of solution for an ounce of trouble. Instead, the engineers put that "up-shift" light on the dash to tell the inspectors how to drive the car for testing. If they up-shifted the instant the light turned on, which was a little too early for comfortable driving, it would pass the emissions tests. This is a classic example of where the politicians, who know nothing about cars, were satisfied, and their goals were achieved, but a momentary glitch could wipe out common sense.
This didn't apply to cars with automatic transmissions, and it never stayed on steady, so I'm back to researching what your light is for.
Mar 16, 2017 at 10:00 AM
