Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ranger
Drivetrain
Transmission
Vehicle Speed Sensor
Location
Vehicle speed sensor location I don't know where to find it?
2000 FORD RANGER
111,965 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
CAROLYNNEL2
MEMBER
I don't know where to find it. It's not the one on the rear axle.
Mar 26, 2019 at 12:39 AM
Experienced Mechanic
Here are some guides that will help with testing and replacing speed sensors in case you need this info as well:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
The reason you are having an issue finding it is because Ford only used one rear sensor in the rear differential on these trucks.
I attached the process below from the manual. Please run through this material and let us know if you have other questions. Thanks
Images (Click to enlarge)
Jul 2, 2021 at 12:29 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
