After replacing the output speed sensor car will not start
209,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
GABESMAMA2015
We replaced the speed sensor that goes into the transmission and now the car will try to start but not crank.
Jan 25, 2020 at 2:39 PM
SCGRANTURISMO
  • 4,897 POSTS
It sounds like you have a bad sensor that is shorted out which will shut down the PCM, but to be sure unplug the sensor to see if it starts, if so get another sensor to fix the problem.
Thanks,
Alex
2CarPros
Jan 25, 2020 at 9:59 PM
