Speed sensor
198,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
LANE HULSEBUS
All gauges stopped working and neutral lock out will not disengage. I have checked all fuses and relays. Trying to get idea which direction to go in? Car runs great. Front end suspension was recently rebuilt due to curb collision while hydroplaning. Spindles rack and pinion axle arms the works was not sure if impact could have messed with speed sensor or computer?
Dec 29, 2017 at 5:19 AM
KHLOW2008
  • 41,812 POSTS
Hi Lane,
This problem is most likely due to a wiring fault. It he fuses are good, then it is possible some power supply or grounding circuit has been disrupted.
Check repair area for poorly grounded circuits. Since the gear shift is locked, check the brake lights to see if they are working.
Check the gauge fuse for power supply.
K H Low
Dec 30, 2017 at 4:45 PM
