Speed sensor
159,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUSH TERRI LYNN
Can a speed sensor cause your vehicle to run funny and idle funny?
Dec 11, 2018 at 6:11 AM
Good afternoon,
Do you mean a transmission speed sensor? If you do, then no, it cannot.
You have a crankshaft position sensor for the engine that could cause this but it would set a code if it did. Do you have any codes set?
https://www.2carpros.com/articles/engine-surges
The other possibility is a dirty throttle body. I would try that first before moving on to anything else.
Dec 11, 2018 at 6:23 AM
