HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Santa Fe
Engine
Symptoms
Runs Rough
Speed sensor
BUSH TERRI LYNN
MEMBER
2008 HYUNDAI SANTA FE
6 CYL
2WD
AUTOMATIC
159,000 MILES
Can a speed sensor cause your vehicle to run funny and idle funny?
Tuesday, December 11th, 2018 AT 2:11 PM
MECHANIC
Good afternoon,
Do you mean a transmission speed sensor? If you do, then no, it cannot.
You have a crankshaft position sensor for the engine that could cause this but it would set a code if it did. Do you have any codes set?
https://www.2carpros.com/articles/engine-surges
The other possibility is a dirty throttle body. I would try that first before moving on to anything else.
Tuesday, December 11th, 2018 AT 2:23 PM
Please
login
or
register
to post a reply.
Related Engine Runs Rough Content
Running Poorly
Girl Friends Car I Have Had Problems With It For About The Last Year Car Will Run Decent Get Me To Work Stuff Like That Always Seem That It...
Asked by
Shel13
2002
HYUNDAI SANTA FE
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
2002 Hyundai Santa Fe Engine Running Rough????
I Haven't Been Driving My Car For About 2 Weeks, When I Got In It Today And Started It, The Motor Was Sounding Very Rough And The Check...
Asked by
CElkins
1 ANSWER
2002
HYUNDAI SANTA FE
2004 Hyundai Santa Fe Runs Very Rough After It Rains
It Rained Heavy This Weekend And On Monday The Car Started But Idled Rough And The Check Engine Light Came On. It Can Barely Chug Along On A...
Asked by
DANNY O
1 ANSWER
2004
HYUNDAI SANTA FE
Engine Misfire?
To The Diagnostic Test Number 2 Cylinder Is Misfiringi Had A Computer Problem Before, Could It Be A False Reading And In A Bigger Problem...
Asked by
squril
1 IMAGE
2008
HYUNDAI SANTA FE
Engine Screeching Noise
Car Makes A Screeching Noise When I Start It And Sit In Park, Or When I Change Gears And It Goes Through Neutral For A Moment On The Way To...
Asked by
Deboosuepo
1 IMAGE
2008
HYUNDAI SANTA FE
VIEW MORE
Topdon OBD2 Scanner Review - This thing rocks
How to Read Codes
How to Read Codes
