Speed odometer not working and no tail light and now no crank
130,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
JOUAPAOV
Replace headlight switch and speed sensor. While cranking smoke came out, after that no crank. Can not locate what was burn out. Try direct from starter to but no spark at all.
Jun 29, 2015 at 8:06 AM
HMAC300
  • 48,601 POSTS
check by pic if smoke came out inside probably the ignition switch.
Jun 29, 2015 at 11:33 PM
