Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Pacifica
Brakes
Master Cylinder
Replace/Remove
Brake master cylinder is bad
2006 CHRYSLER PACIFICA
181,000 MILES • 4WD • AUTOMATIC
KATHLEEN D BOOTH
MEMBER
1 POST
I did looked online but cant find anything can you help?
Feb 29, 2020 at 3:01 AM
Experienced Mechanic
For starters here is a guide that will help with replacing it:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Also, you are going to have to bleed the brakes so here is a guide that will help with this:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Below you will find the process from the manual. Please let us know if you have other questions. Thanks
Images (Click to enlarge)
Mar 11, 2021 at 11:23 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
