Speedometer not working?
TURBO • 4WD • AUTOMATIC
SAMUEL WIRE
Oct 15, 2026 at 7:37 AM
MECHTRIX
  • 583 POSTS
This car has a vss/ vehicle speed sensor .. (and /or) abs input to the speedometer cluster this car was made 2 ways one got the speedometer signal from the vss wich is attached to the transmission ..and the other gets it speed signal from the abs sensors down at the wheels not sure wich type yours is but the best way to find out is with a bidirectiinal scan tool there most likely a code ..
it will reveal it to you right away and with that tool you can test all the components pretty fast too so you can isolate wich part is acting up ..also
If you have a abs or check eng ect light on the dash chances are its having trouble with one of the abs wheel sensors but if not then its most likely the vss mounted to the transmission wich ever one your car has but its always better to have a scanner to find out for sure when it comes to this type of problem..
also its a bit more rare but every now and then its the actual speed cluster itself ..especially if its completely dead and if its been that way for a while ...yeah on that note id say get it scanned
Oct 15, 2026 at 7:47 PM
