Car will not go faster than 60 mph
168,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
LISA JOHNSON
Switched the throttle sensor and accelerator sensor. what's wrong?
Nov 6, 2019 at 9:03 AM
  • 110,251 POSTS
Hi:
Anytime there is that much of a power loss, I suspect there is an issue with the catalytic converter. If it is plugged, you will have a major power loss.
Here are a few links to look through. The first explains symptoms and the second is related to testing. Check this and let me know what you find. Also, let me know if the check engine light stays on when running as well as if you pulled any diagnostic trouble codes.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Let me know what you find.
JOe
Nov 8, 2019 at 7:36 AM
