Specifications for tune up and engine oil needed?
2010 DODGE JOURNEY
245,270 MILES • 3.5L • V6 • 4WD • AUTOMATIC
JUDIE_SIMMONS
  • 57 POSTS
I am just trying to get some general information on the vehicle listed above SXT model and some information on a tune up and just a little general information on used different kind of motor oil either lower or higher than what is used or said on the oil cap.
Mar 2, 2023 at 3:39 PM
  • 110,241 POSTS
As far as a tune-up, vehicles with coil-over plugs don't require as much. If you look below, I attached a list of things listed under tune-up. Most of the things listed are for inspection.
The things I highlighted are what I would recommend being replaced.
As far as the motor oil is concerned, I'm not sure what you are looking for. The manufacturer recommends 10W30. See pic 2
With the number of miles on the engine, I wouldn't go thinner. You could go a bit heavier if you are located in a warm climate. However, I wouldn't go any more than 10W40. Also, that weight would be okay if the average temperatures are around 70 degrees and really don't get much colder than 40 degrees.
Let me know if this helps or if you have questions.
Mar 3, 2023 at 12:32 PM
JUDIE_SIMMONS
  • 57 POSTS
Okay. thanks for the information.
Mar 8, 2023 at 2:28 AM
  • 110,241 POSTS
You are very welcome. Let me know if you have questions or if I can help in any way.
Take care and feel free to come back anytime in the future.
Mar 8, 2023 at 11:05 AM
JUDIE_SIMMONS
  • 57 POSTS
What is the issue when the car loses speed randomly then catches back up?
Mar 8, 2023 at 11:34 PM
  • 110,241 POSTS
Hi Judie,
That type of issue can be the result of a few things. For example, if it happens when you are climbing a hill (under a load), it would likely be a fuel pressure issue.
If it happens regardless of the load on the engine, it could be a partially plugged catalytic converter, a transmission slipping, an engine vacuum leak issue, and the list goes on.
Can you think of anything that stands out when this happens? For example, are you climbing a hill, are there any strange sounds or odors, or does it only happen when it's at operating temperature?
Let me know. Also, if the check engine lamp stays on while the engine is running, have you had the computer scanned for diagnostic trouble codes? If so, do you have the codes?
Let me know as much as you can about what is happening.
Take care and hang in there. We'll figure it out together.
Mar 9, 2023 at 12:07 PM
JUDIE_SIMMONS
  • 57 POSTS
Can I get more information on a tune up and the directions and diagram on how to do the tune i know there are 6 spark plugs I just don't know what is the number position from right to left where is the 1st and where is the 6th or from left to right and is there wires or coils.
Mar 10, 2023 at 2:07 AM
  • 110,241 POSTS
No problem. I attached a pic below that identifies the cylinder numbers. There is an arrow in the pic. That points towards the front of the vehicle.
Next, your vehicle has a coil pack for each cylinder. It's called a coil over because to remove the spark plugs, the coil needs to be removed. See pic 2. When you do this, I suggest only doing one at a time to prevent mixing up any of the connectors. There is one bolt that holds the coil pack in place. I believe it is 10mm. Disconnect the electrical connector, remove the bolt, and gently twist back and forth while pulling upward.
Once the coil pack is removed, the spark plug is down inside the plug tower. You will need an extension on the spark plug socket to reach them.
Also, here is a link that explains in general how to tune an engine. You may find it helpful.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Let me know if this helps. Also, if you have questions, don't be worried about asking. I'll get you through it.
Mar 10, 2023 at 1:28 PM
JUDIE_SIMMONS
  • 57 POSTS
What is the issue that causes the car to stall and or not start up?
When it does this, I wait for about 5 minutes or so then try to start it then it starts right up sometimes, or I will put it on the N then rock the car back and forth then put it in Park then it starts right up.
Mar 15, 2023 at 9:23 AM
  • 110,241 POSTS
I have a couple of questions. When it doesn't start normally, is that with the engine cold? Does it only stall when warm?
I ask because there are a few different things that can cause what you described. For example, if it only stalls when warm and takes some time to restart, it could be a failing crankshaft position sensor. There also could be a fuel pressure issue, a failing idle air control valve, the engine coolant temp sensor could be faulty, or even an engine vacuum leak. If you haven't checked for a leak, here is a link that explains how. Try this and let me know if anything is found:
Also, take a look at this link. It explains common symptoms of an engine vacuum leak. See if anything mirrors what you experience.
Let me know as much as you can. Also, if this is the original engine, it could simply be wearing out and has low engine compression.
Mar 15, 2023 at 12:05 PM
JUDIE_SIMMONS
  • 57 POSTS
When we last talked, I think the issue with the car stalling is caused by the failing CP Sensor because the issue is starting to happen more times the not, and it even happened once when the car was just being started for the first time in the morning.
Apr 26, 2023 at 8:56 PM
  • 110,241 POSTS
The crank sensor is one thing that can cause the problem. There are others. Have you been able to check for vacuum leaks? When the engine stalls and won't restart, have you checked to see if there is an RPM signal?
Apr 27, 2023 at 11:34 AM
JUDIE_SIMMONS
  • 57 POSTS
How and what do I need to do the test for the crankshaft the vacuum leak and the RPMs? what do I need to be look for in all the tests?
Apr 28, 2023 at 11:33 PM
  • 110,241 POSTS
If the crankshaft position sensor fails, you have three things you can do. These must be done when the engine won't start. First, check to see if there is spark at the plugs. A faulty sensor will prevent spark.
Here is a link that explains how this is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Also, you can use a live data scan tool to see if there is an RPM signal when cranking. It won't be present if the sensor has failed.
One other thing. If your vehicle has a tachometer, see if it moves a little when cranking. That will indicate if there is an RPM signal as well.
Do me a favor. Before doing anything, read through this link and let me know if anything mirrors what you are experiencing. I suspect it is the sensor because it requires you to wait for it to restart. When these sensors begin to fail, they are adversely affected by heat. Once they cool a bit, they can start working again.
Take a look and let me know your thoughts:
Apr 29, 2023 at 12:45 PM
