Spark plugs will not loosen?
188,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
MICHAEL NEEDS HELP
  • 23 POSTS
What would cause the plugs to not loosen (even tried putting a pipe over ratchet like a breaker bar) I have stopped because the 2-plug did the same thing. What's the trick to getting them off when they are that tight?
Oct 23, 2023 at 5:24 PM
BORIS K
  • 836 POSTS
Seized spark plugs can be difficult to remove.
Best apply some graphite penetrating spray, let soak over night.
Use a good quality spark plug socket so it does not round off the spark plug.
A good video:
https://youtu.be/9OTsu5MizSE?si=Ep3eoMkepc2OiXdW
Cheers, Boris
Oct 23, 2023 at 8:54 PM
