Spark problems on spark plugs
118,234 MILES • 1.0L • 3 CYL • 2WD • AUTOMATIC
WATSON CHIJUMBA
Toyota Duet three piston engine will not start. It does not produce power on the plugs, and the nozzles also are not opening.
Dec 12, 2017 at 2:26 PM
KHLOW2008
  • 41,812 POSTS
Are there any trouble codes? Did you check the fuses? When ignition switch is turned on, did the Check Engine Light turn on? Was any repairs done prior to this occurring?
No spark is due to a fault with the crank sensor while no injector pulse is due to missing signal from the cam sensor. For both to fail at the same time , the more likely cause would be power supply or a bad ground circuit.
Dec 14, 2017 at 10:40 PM
WATSON CHIJUMBA
We worked on the head cylinder, the inlet valves were not closing.
Dec 16, 2017 at 2:55 PM
  • 55,721 POSTS
It sounds like a system ground has left off when doing the repair work. Can you please double check the grounds and get back to us?
Cheers, Ken
Dec 18, 2017 at 5:01 AM
