Spark plugs wires stuck?
128,000 MILES • 2WD • AUTOMATIC
DANIEL NELSON2
  • 44 POSTS
The spark plugs wire I. The back are stuck and need help getting them off.
Mar 2, 2025 at 9:03 AM
  • 55,721 POSTS
Yep, they can get stuck on there pretty good. You need to twist the plug wire first which helps break the seal loose and then wiggle while twisting. Here is a link to a set of plug wire pliers which do a good job if the aforementioned does not work for $21.00.
https://amzn.to/3DbE0yV
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Mar 3, 2025 at 4:18 AM
DANIEL NELSON2
  • 44 POSTS
Yeah here I'm sending you a video right now of exactly what I'm trying to do.
Mar 3, 2025 at 4:25 AM
DANIEL NELSON2
  • 44 POSTS
Would highly value the help. thanks ahead of time.
Mar 3, 2025 at 4:36 AM
  • 55,721 POSTS
Yep, that is tough to get to. I would remove the ignition coils and I would remove the engine torque mount, (do not start engine) then while in park push the car forward a few inches which will cause the engine to roll to the front of the engine bay so you can get your hands back there, here is how. Check out the images (below). Let us know how it goes.
Mar 4, 2025 at 2:15 AM
