Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Land Rover
Freelander
Ignition
Spark Plug
Spark plugs not firing
2001 LAND ROVER FREELANDER
96,000 MILES • 2.5L • V6 • 4WD • AUTOMATIC
JO1962
MEMBER
1 POST
The engine cranks but there is no voltage going to the ignition coil not even to spark plugs.
Dec 4, 2019 at 8:02 PM
Experienced Mechanic
There is an ignition coil relay we need to check. here is a guide and the relay location so you can see whats going on:
Here is the fuse panel location and identifications. Please test with the key on.
Images (Click to enlarge)
Dec 8, 2019 at 4:42 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
