Spark plugs and coil change
155,000 MILES • V8 • 4WD • AUTOMATIC
ITWASHESOFF
Have had the plugs and coils changed, as it was missing on one cylinder (plug broken). Have been told now that there is no compression in the motor. What would cause this as apart from the initial miss, there was no problem?
Oct 10, 2019 at 5:57 AM
STEVE W.
  • 15,421 POSTS
Welcome to 2CarPros. To go from a single cylinder misfire to no compression in the engine is either a timing chain or camshaft failure. Personally I would test it myself to verify this as that engine is normally very reliable. It isn't hard to do and you can borrow the tool from many parts stores. https://www.2carpros.com/articles/how-to-test-engine-compression
If it does test low or no compression then it comes down to the rest of the vehicles condition. A used engine or a re-manufactured one are both options. However if you don't have the tools to do the swap it may cost you more than you want to spend.
Oct 10, 2019 at 6:35 AM
