Spark plugs and bolt picture of rear top of engine
2003 FORD TAURUS
40,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
SADYBO22
I was taking spark plugs out, is there any chance I put the socket on the wrong bolt and loosened it up with it being the same size as a spark plug?
Mar 4, 2018 at 12:09 PM
  • 31,937 POSTS
I do not think so, nothing comes to mind that may be a concern, but then i do not know where you placed the socket either. Do you have a problem after changing the plugs?
Mar 4, 2018 at 6:12 PM
SADYBO22
Bad luck is my middle name. after plugs and wires were put in, I checked my oil it was so low I got nervous. I looked under the car, I did not know my oil pan gasket could leak that much. I thought by not being able to see the plug, I may have just put the socket on some lose to it and loosened it. I should have never done it at night. thank you for your response. I would recommend you guys everywhere.
Mar 7, 2018 at 8:26 AM
SADYBO22
And no problem, running greatly.
Mar 7, 2018 at 8:27 AM
RENEE L
  • 1,260 POSTS
Hello SADYBO22,
Happy to hear you were able to fix the problem. Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Mar 8, 2018 at 6:02 AM
