Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Ignition
Spark Plug
Torque
Spark Plugs
2007 TOYOTA COROLLA
240,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
YAZIDAN
MEMBER
Do I need to put ant-seize or not?
Thank you
Feb 12, 2024 at 10:18 AM
STEVE W.
Experienced Mechanic
18 ft lb or just snug. Be sure to check the coil boots for damage and any oil leakage that point to leaking O-rings on the valve cover letting oil into the tubes.
Feb 12, 2024 at 12:12 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
