Spark plugs replacement
260,000 MILES • 0.9L • 4 CYL • 2WD • AUTOMATIC
COCO281
How do I replace my spark plugs? What kind should I get and tools to use?
Nov 23, 2018 at 12:21 AM
TECH2018
  • 5 POSTS
Begin with the vehicle on level ground, engine off (cold) with the emergency brake set.
Step 1 - Some engine's are designed with a plastic cover over the ignition coils and spark plugs.
SPARK PLUG COVER
Step 2 - Use a socket or wrench to remove the nuts holding down the cover.
REMOVING SPARK PLUG COVER NUTS
Step 3 - After all mounting nuts have been removed, gently remove the cover.
REMOVE SPARK PLUG COVER
Step 4 - On COP (coil over plug) ignition system designs the spark plugs are located beneath the ignition coils.
IGNITION COILS
Step 5 - Once the ignition coils have been uncovered, remove the coil mounting bolts. (Note: coil wiring may need disconnecting prior to this step.)
REMOVE IGNITION COIL MOUNTING BOLTS
Step 6 - Next, remove the ignition coils from the spark plug wells and place them off to the side. (Note: Inspect ignition coil for corrosion or signs of arcing.)
REMOVING IGNITION COILS
Step 7 - After the coils have been removed, use a spark plug socket to remove the spark plugs, this socket is specially designed to hold and protect the spark plug from damage.
SPARK PLUG SOCKET
Step 8 - Use a ratchet and extension to remove the spark plugs, ensure the socket is completely on the spark plug before removal to avoid damage.
REMOVING PARK PLUGS
Step 9 - Once the spark plug has been removed, inspect the plug for damage and wear.
WORN SPARK PLUG
Step 10 - Compare the new spark plugs to the old units to ensure a proper installation. In most cases spark plugs do not need to be re-gaped as they are manufactured to the correct measurement for each application.
NEW SPARK PLUG
Step 11 - Before installing the new spark plugs, apply a thin layer of lubricant (anti-seize) to avoid thread galling (stripping).
APPLY LUBRICANT TO SPARK PLUG THREADS
Step 12 - Insert the spark plug into the socket while ensuring a snug fit, (the spark plug shouldn't fall out of the socket on its own).
INSTALLATION READY SPARK PLUG
Step 13 - Gently lower the spark plug down into the plug well (do not drop plug), continue installing the spark plug while threading by hand.
LOWER PLUG INTO WELL
Step 14 - Once the spark plug have been installed by hand, use a ratchet to tighten to manufacturers specifications (snug, do not over tighten).
TIGHTEN SPARK PLUGS
Step 15 - Next, reposition the ignition coils for re-installation.
REINSTALLING IGNITION COILS
Step 16 - After installing the ignition coils, reinsert the mounting bolts and tighten.
TIGHTEN IGNITION COIL BOLTS
Step 17 - Once all coil mounting bolts are tight, reinstall the ignition cover back into place.
REINSTALL SPARK PLUG COVER
Step 18 - Install all mounting bolts and tighten, double check all steps to ensure a correct completion.
TIGHTEN IGNITION COIL SPARK PLUG COVER
Step 19 -  When replacing spark plugs always check the plug condition, this inspection can detect problems inside the engine such as rich mixture, low compression or failed injector.
CARBON FOULED
Step 20 - When a spark plug is wet with oil there is a problem with the piston rings or valve stem seals, additional problems include plugged oil drain back holes in the cylinder head.
WET SPARK PLUG
Step 21 - Before installing a new spark plug inspect the air gap in case the plug was damaged during shipping.
MISADJUSTED AIR GAP
Step 22 - Visually inspect the air gap and adjust to manufacturers specifications.
CORRECT AIR GAP
Step 23 - A spark plug is constructed of a metal housing and a porcelain insulator which is very brittle and if broken or cracked will misfire so use care when handling.
Helpful Information
After replacing spark plugs the engine could stall, idle high or low, this is normal as the computer is re-learning the resistance of the ignition system which effects ignition timing. Some engine's are designed using spark plug wires which are easily removed (twist the boot to loosen seal) before removing wires. If the engine is running rich all of the spark plugs will have a black or grey soot covering the spark plug electrode and if lean all of the spark plugs will be clean and white. If one spark plug electrode appears different than the remaining spark plugs, that cylinder is having a problem. The inside of a spark plug socket is lined with a rubber cushion to safety support the spark plug insulator. Most engine's are designed with a COS system (coil over spark plug) which has no plug wires just ignition coils, other systems include HEI (high energy ignition) which utilizes a distributor and spark plug wires.  If spark plug threads are damaged use a thread cleaner or tap loaded with grease to catch the metal chips that would normally go into the combustion chamber, also use a can of compressed air with the long plastic extension inserted down into the cylinder to blow out excess particles helping the removal of additional particles.
Tools and Supplies Needed
Socket set,wrench set, shop towels, protective gloves and eye wear. Carburetor cleaner set of new spark plugs.
Best Practice
Allow the engine to cool before removing spark plugs. Mark plug wires with a small piece of numbered tape to identify cylinder positions.Only install the correct spark plugs, design issues can cause internal engine damage.Remove debris from the spark plug well before removing spark plugs. Only tighten spark plugs to "snug" and install a small portion of anti-seize grease to ensure proper installation. Double check installation of spark plug wires
AC Delco Type .................... 41-627
This is the recommended type and part number recommended by the manufacturer.
1.02 mm (0.040 in)
And above is the recommended gap for the spark plugs.
If you have anymore questions please feel free to ask. Thank you and have a great day.
Nov 23, 2018 at 12:58 AM
  • 55,746 POSTS
This guide will give you a step by step on how to replace the spark plugs.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Cheers, Ken
Nov 23, 2018 at 8:48 AM
