I replaced the ignition coil connectors. When plugging back in the wires I may have switched two of the wires in cylinder 1. The car is still starting, everything sounds normal, no harsh start or idling.
If two of the wires are switched, will the car still start normally? How can I tell that the wires if the wires are in the correct spot?
Nov 18, 2022 at 4:41 AM
