After replacing the spark plugs and wires the engine is misfiring?
2003 CHEVROLET TRUCK
179 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
EDGARSALAZAR29
I change the spark plug wires and spark plugs and now i got a misfire. Spark plug wire diagram needed.
Apr 21, 2021 at 1:47 PM
HARRY P
  • 2,292 POSTS
Hello there. I'm attaching the image that I think you need. Hopefully this gets you going again.
Tip: the best way to avoid this situation when doing spark plugs and wires is simply do do it one cylinder at a time. This helps you too keep things organized and straight while avoiding confusion.
Good luck and let us know if this helps out if you need more help with your truck.
Apr 21, 2021 at 2:14 PM
