Spark Plug Tube Gaskets
175,000 MILES
DOBEDOO
  • 13 POSTS
Hi mmprince4000:
I just finished my first valve cover last night and I have a few questions about completion.
1) Lost a nut to the bay/ground (the one next to oil cap). Partially torqued the three to 35. Is this OK or will that warp my cover? When I get the new nut can I just add it or do I have to pull cover and start over?
2) Spark plug tube seals - How do I check if they are installed properly before I power up? If I need to redo these I want to know before I get oil everywhere. Tried replacing one boot and it fit tightly but I don't know if that's conclusive. One of these (#4 in pic) is installed slightly deeper than the others.
3) One of the humps (left) did not seat in the VC but the gasket fit perfectly otherwise. I was hoping torquing would resolve it but I don't know for sure.
May 21, 2013 at 12:22 PM
WRENCHTOSS
  • 16 POSTS
It will leak badly if you don't replace the missing nut ..
May 21, 2013 at 12:35 PM
DOBEDOO
  • 13 POSTS
The question is for mmprince. Thanks.
May 21, 2013 at 1:05 PM
  • 31,937 POSTS
You better respond to the original post, he may not see the new post, just add it to the bottom of the first post.
May 21, 2013 at 9:20 PM
DOBEDOO
  • 13 POSTS
OK. Thanks. In the meantime it wouldn't hurt to get your take too.
May 22, 2013 at 12:56 AM
MMPRINCE4000
  • 8,548 POSTS
The nuts are a cap head M6x1.0, you can get at Toyota or a junk yard. I would remove cover, the Felpro Viton gaskets can be reused.
I use a 1/4" ratchet and socket to tighten them, starting in center. get them "snug". I also put black RTV on the distributor "hump" and the cam "hump.
The tube seals look good in the picture, I use a large socket same size as tube seal to install. Put cover face down (like first pic) on a concrete surface to drive in tube seals.
The bottom of the tube seal is a steel base. When properly installed the seal will face up towards top of cover.
May 22, 2013 at 1:15 AM
DOBEDOO
  • 13 POSTS
Do you know the nut thread size so I can get a quick replacement?
If I remove cover can I reinstall gasket mostly dry like the first time since I didn't power up or do I need to cover with RTV second time.
If you compare the humps in the VC you can see there is a gap on the left. Will this be OK when torqued down or will it leak and I need to get a new gasket?
Both of these are good and don't look leak prone?
Seals 1-3: Tube Sits Above Seal
Seal 4: Tube Sits Nearly Flush to Inner Ring
Thanks a lot
May 22, 2013 at 2:15 AM
MMPRINCE4000
  • 8,548 POSTS
Nut size is M6 x 1.0.
Gasket can be re-installed.
Make sure you have gasket installed properly, reverse it to make sure it is on correctly as a test. If it fits hump better when reversed, then install.
Tube seals can also be installed wrong, the bottom that is inside cover should have a metal base.
May 22, 2013 at 9:47 PM
DOBEDOO
  • 13 POSTS
Are you looking at my images before you answer because it doesn't seem so?
May 23, 2013 at 4:28 AM
MMPRINCE4000
  • 8,548 POSTS
From what I can see the tube seals look good.
May 23, 2013 at 8:07 PM
