spark plug removal
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
WALTER YOUNG JR.
should the plugs be remove when hot are cold?
Oct 17, 2020 at 9:28 PM
Good morning,
Since you have the 3 valve, no, it should not.
I would crack them all loose and spray some lube into the well and let it sit. Then proceed to remove the plugs.
https://www.2carpros.com/articles/how-to-change-spark-plugs
I attached a TSB for you to view about removing them without breaking them.
TSB 08-1-9
01/21/08
SPARK PLUG REMOVAL INSTRUCTIONS - 5.4L 3V
FORD:
2004-2008 F-150
2005-2008 Expedition, F-Super Duty
LINCOLN:
2005-2008 Navigator
2006-2008 Mark LT
This article supersedes TSB 06-15-2 to update Vehicle Applications, Service Procedure and Part List.
ISSUE
Some 2004-2008 F-150, 2006-2008 Mark LT, 2005-2008 F-Super Duty, Expedition, and Navigator vehicles built with a 5.4L 3-V engine and has a engine built date before 10/9/2007, may experience difficulty with spark plug removal. This may cause damage to the spark plug and leave part of the spark plug in the cylinder head.
ACTION
Refer to the following Service Procedure for techniques to remove the spark plugs and extract broken spark plugs.
SERVICE PROCEDURE
The engine build date can be read on the left hand cam cover information sticker.
To remove spark plugs without damage, it is necessary to adhere exactly to this procedure before removal is attempted.
CAUTION
DO NOT REMOVE PLUGS WHEN THE ENGINE IS WARM OR HOT. THE ENGINE MUST BE AT ROOM TEMPERATURE WHEN PERFORMING SPARK PLUG SERVICE. REMOVING THE SPARK PLUGS FROM A WARM/HOT ENGINE INCREASES THE CHANCE THE THREADS COULD BE DAMAGED.
Spark Plug Removal Procedure
1. Remove the coil-on-plug assemblies and thoroughly blow out the spark plug wells and surrounding valve cover area with compressed air.
2. Back out the spark plugs no more than 1/8 to 1/4 of a turn. Using Motorcraft(R) Carburetor Tune-Up Cleaner, fill the spark plug well just above where the jamb nut hex sits (1/2 - 3/4 teaspoon). A minimum period of 15 minutes of soak time is required. The cleaner will wick down to the ground electrode shield and soften the carbon deposits in this time. DO NOT WORK the spark plug back and forth at this point.
NOTE
COMPLETELY REVIEW THE PRODUCT LABEL FOR THE MOTORCRAFT CARBURETOR TUNE-UP CLEANER PRODUCT - USE AT ROOM TEMPERATURE AND SHAKE WELL.
CAUTION
EXCESSIVE MOTORCRAFT(R) CARBURETOR TUNE-UP CLEANER, OR REPEATING THE PROCESS SEVERAL TIMES WITH TOO MUCH CLEANER FLUID, COULD INTRODUCE ENOUGH LIQUID VOLUME TO HYDRO-LOCK THE ENGINE.
CAUTION
DO NOT USE AIR OR POWER TOOLS FOR SPARK PLUG REMOVAL. SPARK PLUGS MUST ONLY BE REMOVED WITH HAND TOOLS.
3. Slowly turn the spark plug out. Some screeching and high effort may be noticed, but not in every case. The expected removal torque is about 33 lb-ft (45 N.m), but should decrease on the way out. If it is higher, try turning the spark plug back in a half turn, then back out again. If the turning torque still seems high, repeat the back and forth rotation along with introducing additional Motorcraft Carburetor Tune-Up Cleaner to reduce turning effort.
Separated/Broken Spark Plug Removal
If the spark plug does come apart even after following the Spark Plug Removal Procedure, it will break in one of two modes:
Oct 17, 2020 at 9:42 PM
  • 55,770 POSTS
I would do the spark plug change when the engine is cold. here is a video of the job being done correctly:
https://youtu.be/E6oier7agkY
Oct 19, 2020 at 3:18 AM
TY
Best practice is to remove spark plugs when the engine is cold. Aluminum heads get soft and weak when warm.
Feb 16, 2024 at 3:52 AM
