Spark plug misfire
245,000 MILES • 3.2L • 6 CYL • AUTOMATIC
MEMBER8419
  • 8 POSTS
I changed my spark plugs. I set them at. 045 instead of. 050. It's missing bad.
So can I purchase more spark plugs and set the at. 050? it's been like 2 weeks since I changed them.
Oct 29, 2019 at 3:57 PM
Good morning,
Did you have the misfire prior to the plug replacement?
Yes, you can change them again and you must follow the spec. Do not vary away from the spec.
Oct 29, 2019 at 8:33 PM
MEMBER8419
  • 8 POSTS
Just make sure they are set at. 050.
Oct 29, 2019 at 8:43 PM
The spec is attached.
Oct 29, 2019 at 8:49 PM
MEMBER8419
  • 8 POSTS
What do you mean by spec?
Oct 29, 2019 at 8:50 PM
The gap for the plugs to be set. I would set them at .050.
Oct 29, 2019 at 8:51 PM
MEMBER8419
  • 8 POSTS
What is the recommended spark plugs for that car?
Oct 29, 2019 at 8:53 PM
Champion came with it when it was new?
Oct 29, 2019 at 9:27 PM
MEMBER8419
  • 8 POSTS
Thanks for the information.
Oct 30, 2019 at 2:00 AM
You are welcome.
Always glad to help.
Oct 30, 2019 at 2:30 AM
