Spark plug replacement
102,900 MILES • 1.4L • 4 CYL • 4WD • MANUAL
NICOLE BROADBENT
I took off the cover for the spark plugs, and the coil boots did not come out. So I can't get to the spark plugs to exchange them. What do I do now?
Jun 17, 2019 at 4:56 AM
Hi Nicole,
Here is the procedure to remove the ignition coil and the boots should be underneath. It looks like there is a special tool needed and I suspect this is needed so the boots come out with it.
If you did not have this tool, then you should just be able to use some needle nose pliers and pull them off but this may damage them. However, if you submit a picture of what you have currently then I may be able to come up with a better idea of how to get them out.
Let me know and we can go from there.
Jun 17, 2019 at 5:37 AM
NICOLE BROADBENT
I didn't know about the special tool beforehand. I tried needle nose pliers. Eventually the boots came off in pieces. Now I have to go and buy a whole new part. :(
Jun 17, 2019 at 6:12 AM
Understandable. Unfortunately, we have all received this type of education on different things.
Glad you got it figured out. Please let us know if you need more information. Thanks
Jun 17, 2019 at 6:34 AM
NICOLE BROADBENT
I can't get the coil boots out to change the spark plug!! I have tried everything! I got a partial one out, ripped it, but it's still party in, and I can't even get the other ones out!! Help!
Jun 18, 2019 at 4:49 AM
  • 55,694 POSTS
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Here is a video of the job being done:
https://youtu.be/xyqOo5MhgGk
Please let us know.
Jun 18, 2019 at 4:50 AM
