spark plug coil keeps overheating and burning up same cylinder
120,000 MILES
MUSTANGMANXYZ
  • 5 POSTS
same spark plug coil keeps melting now truck does not sound right or run right, what could be the problem I changed all the plugs and put a 3rd coil on and still coil is overheating and now truck sounds wrong
Sep 28, 2013 at 3:00 AM
HMAC300
  • 48,601 POSTS
what's the code?
Sep 28, 2013 at 3:59 AM
MUSTANGMANXYZ
  • 5 POSTS
po 3oo po 303 po306 p0 356 number 6 cylinder is the one that keeps overheating
Sep 29, 2013 at 3:07 AM
HMAC300
  • 48,601 POSTS
misfires are very hard to diagnose but have a pro look at it as you are probably getting to much voltage wrecking the coil. this can be an asd relay circuit problem a pcm , capacitors, or the coil circuit is either open or shorted to ground causeing this
Sep 29, 2013 at 8:35 AM
