What is the torque spec for the spark plugs?
85,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JIMMY13X
I just need to know what is the torque spec for the spark plugs on the truck listed above Laramie 1500 V8 etorque.
Jun 18, 2024 at 9:50 AM
  • 110,248 POSTS
No problem whatsoever.
If you look below, I attached the directions for installing them. The directions include the gap as well as torque specs (13 ft/lbs).
When you reinstall the coil pack, I recommend using dielectric grease inside the rubber boot. It will help prevent contamination and make it a lot easier to remove in the future.
Let me know if this helps.
joe
Jun 18, 2024 at 1:08 PM
