Changing spark plugs. One plug had oil on it. Not around electrode. Any ideas what happened? thanks
Feb 12, 2018 at 7:13 AM
✓Experienced Mechanic
If the spark plug is through the rocker cover there will be a failed seal as part of the rocker cover gasket. it is normally part of the rocker cover gasket set but ask your supplier if this is the case before purchasing.
