Water in the spark plugs
110 MILES • AUTOMATIC
ZEYAD DARADKEH
  • 8 POSTS
Hello. there is water in spark plug plus in the coil. How can me solve this problem please?
Jun 10, 2020 at 5:48 PM
  • 55,845 POSTS
The only time you see this is when the head gasket is blown. does the engine overheat? Lets do a chemical test to confirm the issue. Also can you remove the spark plug and upload a picture?
Jun 11, 2020 at 5:33 AM
ZEYAD DARADKEH
  • 8 POSTS
Many thanks Mr Ken.
I will send you the spark plug.
Jun 11, 2020 at 6:41 AM
  • 55,845 POSTS
Please do I want to get this fixed for you.
Jun 12, 2020 at 2:59 AM
ZEYAD DARADKEH
  • 8 POSTS
Hello Mr Ken.
How are you?
Please find attached pictures of the spark plug.
Best regards,
Zeyad
Jun 12, 2020 at 11:21 PM
ZEYAD DARADKEH
  • 8 POSTS
Hi.
Jun 13, 2020 at 4:51 AM
This appears to have water in the top of the spark plug hole and that would typically only get there if the engine was submerged in water or you have been spraying down the engine with water. It is unlikely for the water to get in the plug hole during normal driving.
Is there any other portion or information to this story? Did you just buy this vehicle or has it been sitting for a long time?
Jun 16, 2020 at 6:54 AM
ZEYAD DARADKEH
  • 8 POSTS
Many thanks Mr KASEKENNY1
I buying it before 1 year with same problem...
I did chick all the resources of water but without any solution...
What i can do it for this problem?
Can me replace any parts to make sure about the proplem?
Best regards.
Jun 16, 2020 at 7:59 AM
I would replace the spark plugs and not worry about the rest of the rust that I pointed to in the picture. The only way to fix that is to replace the head and if there is no issue with the vehicle running then I would leave it alone until it causes an issue and address it then.
I am concerned with those white bubbles as it may be rusted through to the combustion chamber. If it is then the head will have to be replaced.
Jun 17, 2020 at 10:58 AM
ZEYAD DARADKEH
  • 8 POSTS
Dear Mr KASEKENNY1,
Many thanks for the your interest in the my problem...
Can I change the head at home? Is it difficult?
Jun 18, 2020 at 4:22 AM
  • 55,845 POSTS
Like my dad says it just nut a bolts. :) If you have tools we can guide your through the process, but please start a new question to do so.
Please post your new question here, you must be logged in.
Cheers, Ken
Jun 18, 2020 at 5:07 AM
ZEYAD DARADKEH
  • 8 POSTS
Many thanks.
I will do right now.
Jun 18, 2020 at 5:46 AM
