spark near odb reader connect
124,000 MILES • V6 • FWD • AUTOMATIC
ITCOFFMAN
just got back off a log trip and the check engine light was on the whole way returning. after getting home we went to hook up the ODB reader and when connecting it pushed a "red" wire to hit the metal side and a spark happened. the connector does not read anything now and the car dash will light up when trying to start, but just keeps clicking and will not turn over.
Any ideas where to start troubleshooting on this?
Jan 17, 2017 at 10:07 PM
HMAC300
  • 48,601 POSTS
check fuses, then try a security system reset you may have set it off doing that.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jan 17, 2017 at 11:01 PM
ITCOFFMAN
Thanks, found a blown fuse for the computer system. Now ABS and VBS lights will not go out, but at least it is running!
Jan 18, 2017 at 3:01 AM
HMAC300
  • 48,601 POSTS
then have it scanned by a mechanic as ABS may have a problem that is why VBS light is on.
Jan 18, 2017 at 4:03 AM
ITCOFFMAN
They were not on before the fuse was blown. thanks
Jan 18, 2017 at 4:20 AM
HMAC300
  • 48,601 POSTS
it may be something simple, check fuses under hood as you may have blown that one otherwise get it scanned..
Jan 18, 2017 at 4:33 AM
