Car will not start
300,000 MILES
KAMOGELO2010
There is no spark in plugs and I just changed them recently.
Oct 13, 2019 at 12:07 AM
  • 110,248 POSTS
Welcome to 2CarPros.
First, this vehicle isn't offered in the us, so my technical information is very limited. However, I will try my best to help.
When spark is lost on today's cars, the first thing I think of is a bad crankshaft position sensor. This sensor can break down internally and cause a no spark condition. Interestingly, it can also happen and not set a diagnostic trouble code. Take a look through these links.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Here is a link that shows in general how one is replaced.
______________________
Since there is no spark, that is the first thing I would check. If you have a live data scanner, you can check for an RPM signal while the engine is cranking. If there is none, this is my first suspect.
Oct 14, 2019 at 12:04 PM
