ive repaced the coil three times in the past three weeks.i used an aligator clip on a spark plug to test the spark.there is a hair line spark.i thought it should be wider and brighter. i put my finger over it and there was a little shock,but i thought it should be more,so much more that i would have to pull my finger away.with the distibuter cap off there is spark at the points.new distributer car,rotor,points and condenser,also new plug wires.with the ignition switch on there is 8 volts across the positive and negative terminal of the coil.what do i do next?
May 3, 2013 at 1:53 PM
