Spare tire maximum size
20,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
2018GRANDCARAVAN
  • 7 POSTS
What is largest rim and tire can be used as spare? Not a donut.
Nov 19, 2018 at 12:36 AM
  • 110,246 POSTS
The spare tire should have the same outside diameter size as what is on the car. You should never mix sizes. You also mentioned wheel size. A larger wheel can be used as long as the tire has a lower sidewall profile which again, has the same outside diameter as the tires on the vehicle.
I hope this helps. If I misunderstood your question, please let me know.
Nov 19, 2018 at 10:43 AM
2018GRANDCARAVAN
  • 7 POSTS
I see I did not make my question as clear as it should have been. I am trying to find out the largest size spare tire will fit up under the caravan in the spare carrier.
Nov 19, 2018 at 11:35 AM
  • 110,246 POSTS
No problem. I do not think you will like this, but with the stow and go design, the spare tire location has been moved and will only fit a compact spare tire. A full size tire will not fit.
I wish I had a better answer, but that is the reality.
I hope this helps.
Nov 19, 2018 at 12:22 PM
2018GRANDCARAVAN
  • 7 POSTS
Thank you for your help.
Nov 20, 2018 at 12:09 AM
  • 110,246 POSTS
You are very welcome. I wish I had a better answer, but any and all extra space has been removed from the storage compartment.
I wanted to wish you and your family a Happy Thanksgiving. Also, let us know if you have questions in the future.
Nov 20, 2018 at 9:38 AM
