Sounds likd a helicopter with no speed
2,193,542 MILES • FWD • MANUAL
MR. RICARDO GAIN
To whom it may concern,
Add ons. : Cone air filter,
: free flow exhaust,
:branches
The problem I am currently faced with is that I have recently towed another car and after about a mile and a half there was a sudden loss of power in the acceleration to which I thought was due to towing a vehicle. Then I noticed that it took longer than usual to pick up speed. So I decided not to continue towing any longer, started my engine and attempted to drive as per usual. At these moment my car had difficulty pulling off as well as low drive power with each gear change. And by the sounds of it my car no longer sounds as good as it did before. It sounds more like a chopper and the revs whilst driving sounds as though I am doing seventy miles when I am only doing twenty five.
Any advice or guidance please anybody?
Jul 28, 2016 at 9:55 AM
RIVERMIKERAT
  • 6,106 POSTS
Sounds like you burned up your transmission.
Jul 30, 2016 at 2:36 AM
MR. RICARDO GAIN
Thank you very much for your opinion. I will check to see if that is the problem.
Aug 7, 2016 at 9:41 AM
RIVERMIKERAT
  • 6,106 POSTS
Let us know. You should be able to take it to a transmission shop and have them scan it.
Aug 7, 2016 at 9:50 AM
MR. RICARDO GAIN
Hey guys, thank you very much for your assistance. I've done a check on my car to check if everything is in place and I discovered that my fuel filter wasn't tightly secured. I then tightened, disconnected the fuel relay then connected it again. Let the car idle for a few minutes then drove it and it ran perfect again. Thanks again and I this might be of help to another.
Aug 22, 2016 at 7:29 PM
RENEE L
  • 1,260 POSTS
We are glad you got the problem fixed, please use 2carpros.com anytime
Aug 29, 2016 at 2:29 PM
