Sound is like a bearing knock
381,952 MILES • 1.3L • 4 CYL • FWD • MANUAL
DANIEL GEWERS
Sounded if the car has a bearing knock but we open the engine but the bearings are as good as new and it was well torqued. How do i replace the lifters in the cylinder head and where is it situated? please help.
Apr 2, 2017 at 10:10 PM
HMAC300
  • 48,601 POSTS
before you go any further you should have a professional look at this so you do not waste money on parts that are good. have him check bearings and pistons as it may be that or even a bolt rubbing against something that has come loose. the lifters are in cylinder head if overhead cam along with followers that rub on camshaft.
Apr 2, 2017 at 11:50 PM
