Sound comes when releasing clutch and 4th gear dosen't come back when car is in motion.
AHMER AMMAR
  • 23 POSTS
Hi! sir I want to ask some things few months back I replaced my clutch plate after replacing when I used to release clutch it makes a sound like "CHEEEOOOO". Now few days back I was driving suddenly i felt that when car is moving 4th gear is not coming back to any other gear even to neutral. Please tell what is the cause of both and what should I do?
Nov 13, 2013 at 7:05 PM
  • 31,937 POSTS
Do ypu have clutch pedal pressure, did you fit a full clutch kit or just the clutch plate?
Nov 13, 2013 at 8:45 PM
AHMER AMMAR
  • 23 POSTS
No I just replaced the clutch plate. Well what about the 4th grear. I don't have pressure reservoir for clutch.
Nov 13, 2013 at 10:47 PM
  • 31,937 POSTS
The noise is probably a faulty clutch release bearing, you should always replace the full clutch machine the fly wheel and replace the release bearing. I am wondering if the pressure plate is failing, if it is only 4th gear affected it may well be a transmission problem, have you checked the oil?
Nov 14, 2013 at 6:11 AM
