2000 Nissan Sunny grinding noise in reverse gear
2000 NISSAN SUNNY
80,000 MILES • 4 CYL • FWD • MANUAL
LAKSHITHAW
I hear a grinding noise in the reverse gear, but only after I travel a considerable distance. Cold start(in the morining) it shifts normally. It is only for the reverse gear.
what might be the problem?
Jun 18, 2009 at 2:16 PM
  • 31,937 POSTS
HI there,
Drain the transmission oil & check for metal, see how it goes with fresh oil and report if any sizable shards are present in the oil oil.
Mark (mhpautos)
Jun 18, 2009 at 4:17 PM
LAKSHITHAW
thank you mhpautos for the prompt reply. Will get back to you doing so.
thanks again.
Jun 18, 2009 at 6:49 PM
