A/C not blowing cold air and code p0128
63,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DSHEAIRRA
Hello, my car is having the same issues as someone else did with ac not blowing cold and giving me a p0128 code. what was the issue?
Aug 27, 2019 at 12:10 PM
Good morning,
The 128 code is for a thermostat. It is stuck open and needs to be replaced. It has nothing to do with the A/C issue.
Do you have pressure gauges to give me the pressures?
Aug 27, 2019 at 8:34 PM
DSHEAIRRA
Well, there was another guy on here who had the same issue when you restart my battery the A/C blows cold again.
Aug 28, 2019 at 2:17 AM
Did not see it in the history at all.
Aug 28, 2019 at 2:19 AM
DSHEAIRRA
I think this started a new question. I have a thermostat coming. I hope I find out what is causing it.
Aug 28, 2019 at 2:40 AM
Can we start with your exact issue so I can help?
Aug 28, 2019 at 5:04 AM
DSHEAIRRA
Last week my A/C went out with no warning. then a few hours later the p0128 came up on my car. i went to get it checked they said it is'nt really anything to worry about. Then when i reset the battery my A/C works fine then two days it goes out and the same code pops up shortly after.
Aug 28, 2019 at 12:50 PM
The 128 code is for the thermostat in the engine. It is stuck open and the engine is not getting up to normal operating temperature.
I need the high and low side readings of the AC system while it is running.
Aug 28, 2019 at 7:13 PM
