Shuts off while driving
111,846 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
ADAM.S
Hey! I am having trouble with my car. what happens is that I start the car (with a little fight, need to twist the key for a second) and drive away. After a few hundred meters the car shuts off, when I push down the accelerator pedal nothing happens and the speedometer is lowered to 0. The instrument panel lights start to shine with a solid shine. Oil lamp, battery light and engine light. I first suspected the generator, when I have a mobile charger and charged the battery, it worked to drive the car again in a few hundred meters. The longer the charging time, the longer the driving time. Took the car to a mechanic who, however, read the error codes:
P0700 - Transmission control.
P0741 - Torque converter could.
Could it be above error codes shutting down the engine or could it be something else? These error codes come and go.
Mar 13, 2018 at 12:09 AM
Good morning.
Those codes will not shut the car down.
I would start by charging the battery and load testing it. then check the charging system to be sure the generator is working.
Low voltage is a very common cause for this issue.
Mar 13, 2018 at 12:26 AM
RENEE L
  • 1,260 POSTS
Hello ADAM.S,
If you decide to check the condition of your battery yourself here is a link to helpful information from this site that features written instructions, pictures and a video explaining how to load test your battery yourself. If you need further assistance please come back to 2CarPros.com. We are always happy to help.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Mar 13, 2018 at 3:46 AM
