Hard starting issue?
161,371 MILES • 3.7L • V6 • 4WD • AUTOMATIC
KARL FISHER
It doesn't seem to have a reason but it's getting worse sometimes fire up normal other times it just keeps turning over shut the key off and try again starts normal sometimes it takes 4 or 5 tries to get it to start other starts first try sometimes.
Jun 18, 2023 at 9:06 AM
  • 55,628 POSTS
This happens when there is a vacuum leak, low fuel pressure or the throttle body needs to be serviced. Here are guides to help us fix the problem and I have included images below to help you with your car. Also clean the IAC motor as well.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Use this guide when the engine is cold only:
and
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jun 19, 2023 at 10:46 AM
