Sometimes car vibrates at lower speed
40,389 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
FARAZ HUSSAIN
Hi everyone, I purchased this car used a month ago and its mileage is around 40,400 miles.
In the first week itself, I have noticed Screech sound while taking reverse and then applying brakes. The frequency of hearing this sound is very less.
But three days before, I noticed huge vibration in steering for about three to four seconds while accelerating at lower gear.
And today, I noticed the same problem. The vibration is much greater than before and it happened when I apply brakes. The first vibration occurred when I slowed down in speed breaker and the second happened when I applied brakes during the turn and I was about to lose the control.
So, after noticing these things I went to mechanic explained him everything. Unfortunately, none of the things happened when he took the test drive.
Any idea what is going on with my car? I do not have even basic knowledge to identify where the problem is.
Any help is appreciated.
Feb 6, 2017 at 1:39 AM
STEVE W.
  • 15,411 POSTS
Loud screech while braking and vibration while braking both point to the car needing brakes and probably rotors.
It is also possible it has a bad wheel bearing that is allowing the hub/wheel to move around as you step on the brake. To check it you would jack it up and try to move the tire in/out at the top and bottom as well as from side to side.
Feb 6, 2017 at 2:32 AM
FARAZ HUSSAIN
Thanks Steve for replying. I will check the things you have told.
Feb 6, 2017 at 11:19 PM
