something is stoping the car from turing over and starting
67 MILES • 3.7L • V8 • 2WD • AUTOMATIC
DPAINTER77
When I turn the car to start it doesn't turn over. Took it to auto zone. young kid was working and put the tester on it. First he said it was the starter then a week later it was the alternator not passing the test.. I only get paid once a month and cant afford to keep buying everything they say it is every time. please help me out thanks
May 7, 2015 at 10:10 PM
DPAINTER77
How to tell if an alternator is stooping the car from turning over to start on 1985 chyrysler fith avenue
May 7, 2015 at 10:30 PM
HMAC300
  • 48,601 POSTS
have the battery checked for condition including load test . most places do for free.they can check charging system at same time. if you can jump it and it starts may be a battery or charging problem.
May 8, 2015 at 12:06 AM
DPAINTER77
I have took it to auto zone they did the testing. And said it was a bad altenater. So I went and bought a new one and put it on the car. Took the batter and had it. Tested. It was low so I letter it and they changed it. Come home put it in and still the same thing. When you turn the key to start it doesn't want to turn over and start.Please help. Thanks
May 8, 2015 at 6:20 AM
HMAC300
  • 48,601 POSTS
check items in pic fusible link should have 12V both sides. switch relay with alike relay or go to our site under repair -electrical-how to check a relay
May 8, 2015 at 6:25 AM
