engine starts and then stall like it’s out of gas?
196,047 MILES
GAGNONTRAVIS50
My car’s fuel gauge sometimes doesn’t read right and if it gets below a quarter of a tank, I usually run out of gas, but sometimes even though there’s plenty of gas in the car after it sits, I’ll go to start the car and it’ll start and then stall like it’s out of gas usually if I add a little gas or beat on the tank, it eventually starts back up and then reads back to a normal reading like a half a tank or something so I’m not sure why it does it. It seems to be random even though I know there’s gas in it. The gas gauge will read empty and then I put five dollars worth of gas in it and then when it starts it’ll all of a sudden say it has a half a tank or more I don’t understand why it acts like it’s out of gas even though I know there’s gas in there and then if I add a little bit of gas, it usually starts and I usually have to prime it with the Key a couple times
Mar 23, 2026 at 6:42 AM
  • 55,673 POSTS
Yep, this is a classic fuel pump failure problem, I would drop the fuel tank and install a new pump here is a video to help you.
https://www.youtube.com/watch?v=Lhd0vd8pdBU
If you have problem upload a short video or image so I can help. Let us know how it goes
Mar 24, 2026 at 2:17 AM
