Some exterior lights do not work
97,800 MILES • 3.0L • 6 CYL • TURBO • 4WD • AUTOMATIC
GARYROBO
Hi, was wondering if you could help with my problem? the front left side light, the rear left tail light and both number plate bulbs do not work. all other lights work including the left brake light that is on the same bulb as non working tail light and all fuse from what I can see are fine. any help would be much appreciated.
Aug 18, 2016 at 8:05 AM
HMAC300
  • 48,601 POSTS
have a mechanic scan for codes it may be the front control module or tpim module. check fuse in under fuse box first though.
Aug 18, 2016 at 8:59 AM
