Code P0010 car will not turn over
175,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
BJ2
  • 5 POSTS
I started out a few weeks ago with code P0010, had to put in an engine control module. A day before I put the new ECM in the car, I started the car up. It took two key turns before the car started. First, try you hear a click, second try it started up. It was run so hard, I shut it down within forty five seconds. Mind you, before replacing the ECM, my car ran fine.
Replace my ECM came with codes I had to relearn the system. Codes: P0315-crankshaft not learned, P0602-control module programmer error, P02176-throttle not learned, U0109-lost communication with fuel pump control module A.
When using the scan tool, I do not see P0010 and U0109. (Those two no longer show up.) What I get now when I scan with the scan tool, are P0315, P602, P2126.
I go out the next day, turn the key I get nothing. Let it set, came back, put the key in the ignition, the only thing I could hear was clicking sound on each turn.
Could it be the starter? I have never had any problem with my car starting. No never. Never stalled or any thing of nature. I buy a new battery every two and half to three years, regular on the oil change, I try to keep up on it.
At this stage, i am getting no response for the car when key in the ignition and turning it.
Your position please, what can I do or just try?
Jul 24, 2017 at 6:49 PM
HMAC300
  • 48,601 POSTS
if you put the ECM in yourself then it needs to be programmed by a mechanic in order for it to start and run. the crank/cam sensors need a pro scanner to be synced and told to start/run as well as security needs to be programmed due to being VIN number specific. See picture.
Jul 24, 2017 at 10:37 PM
BJ2
  • 5 POSTS
Thank you for responding to my need for understanding questions about my car. I have to say it solve the problem. My car is now run. Thank you,
Jul 27, 2017 at 2:55 PM
  • 55,691 POSTS
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Jul 28, 2017 at 9:49 AM
