Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Tucson
Drivetrain
Transmission
Torque Converter
Solenoid
Where is the torque converter solenoid located?
2008 HYUNDAI TUCSON
208,000 MILES
ANDRAE33
MEMBER
The vehicle listed above has a 2.7. Is the torque converter solenoid is located on the inside or outside transmission?
Feb 19, 2023 at 10:50 AM
Experienced Mechanic
The torque converter solenoid is mounted on the valve body inside the transmission. To access it, you need to drain the fluid and remove the pan.
I am using information for a 2wd model. If you have an AWD, let me know.
I attached a pic below showing the location of the solenoid.
See pic below.
Image (Click to enlarge)
Feb 19, 2023 at 3:34 PM
ANDRAE33
MEMBER
Thank you. Yes, it's a 4WD.
2008 Hyundai Tucson 2.7. If you can please send me a pic of a 4WD torque converter solenoid location model.
Feb 20, 2023 at 8:53 AM
I looked it up for the AWD. It's the same. I reattached it below. To access it, you need to remove the transmission oil pan.
Let me know if I can help.
Feb 20, 2023 at 12:25 PM
ANDRAE33
MEMBER
Thank you very much. This was very helpful.
Feb 21, 2023 at 7:12 AM
You are very welcome. If you can, let me know if this takes care of the problem. I'm interested in knowing.
Also, if you have questions or if I can help, let me know.
joe
Feb 21, 2023 at 12:45 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
